Hello all,
Not sure if this is the correct place to post this, please correct me if it needs to be moved.
I am planning to build a deck in line with my outdoor pool.
Deck size will be:
5.4m x 6.0m
17.7ft x 19.6ft
I can get hold of either 5.4m or 6.0m deck boards so i have a choice on which way i lay my deck, both options will be no waste/cutting of boards.
I am considering laying the deck boards vertically and using the 5.4m boards.
Plan is to dig footings for posts (under frost line)
Fill with concrete and attach a post bracket (in wet concrete or attach via bolts)
Lay beams (using 2 joists nailed together)
Install joists
Lay decking boards
Questions:
For an area 32.4m square how many footings should be required? I think i can get away with 3x3 = 9 , or should i do 4x4 = 12
Thinking of using a post bracket fitting on top of the footing and then attaching deck post. Is this a good method?
Did try to upload or link to pictures however i do not have permission to do so.
Thank you.
Deck size will be:
5.4m x 6.0m
17.7ft x 19.6ft
Install joists
Lay decking boards
Questions:
Thank you.
