No skills
Greetings all.
I have a very small deck to build 6'x10', any other decks I have built have been a bit bigger and I have tended to use 6x2 for joists (beefing up where needed). Given the small size of this project doing everything in 6x2 seems excessive.
What I was considering doing is a 6x2 outer frame with a doubled up 6x2 in the middle, will 4x2 be suitable for the less than 5' span that's left?? (on 16" or less centres).
I'm not trying to cut corners and will go up on timber size if I need, but do I need to?
Loading is just people and plant pots, no mini hot tubs or anything
