Cutting into corner
SteveF
16 Sep 2013
Maidstone
I am considering cutting an L shape into a solid worktop 900 x 900
leaving 900 450 450 450 450 900
what would be your favorite method to get a clean cut
and leave a crisp internal corner?
yes I could just track saw it and reglue, if that is best approach
Steve
The kitchen fitters will be along with the correct solution shortly, no doubt, but if it were me I would probably cut 4 or 5mm from the line with a circular saw and a hand saw to remove the bulk of the waste, then use a trimming router cutter with a bearing guide against a template to clean everything up, and then finally tidy up the radius to the inner corner with hand-tools (a chisel if the worktop was timber).
I’ve done it it more or less how Mike suggests, though I used the track saw to cut to the line, finished it off with hand saw, then rounded over the top edge with the router.
    25.7 KB
