Cupboard/dressing table construction
Charlotte
16 Jan 2009
Kingston, London/Gloucestershire
I need to source some drawer runners for a cabinet (18mm mdf). The inside depth is 360mm. The cheapest I've found is £4.99/pr for some single extensions of dubious quality. I'd quite like double extensions.
Also, I bought feet along with hinges as Ikea. I cut the feet down and then had no thread :oops: so I need to find some 100mm ones or alternatively, 200mm with full length threads. Screwfix only do 200mm by the bucket (I need 12-16) and I don't know if the thread is full length.
Woodfit do 100mm adjustable feet, assuming its the plastic kitchen type legs you want
The leg is QA482 and you also need the mounting plate QA012 and possible plinth clips
Jason
