I've finally been able to get some time in the workshop (yippee - at last!
) and decided to try marquetry with a scroll saw. Previously when I've tried to cut marquetry with a scroll saw, I've met with utter disaster as the fine veneers splinter. Today, I enjoyed more success
, although my work is definitely not elegant and there are some embarrassing errors.
The big problem I encountered was in stacking the veneers together. With simple patterns and thick veneers, they can be pinned together using veneer pins. However, for more intricate designs and thin veneers which require support, they need to be glued together with an adhesive which can be removed cleanly and easily after cutting. Today I used Copydex, which is fine up to a point but is rather expensive and doesn't last long. In the past, marquetarians used cow gum as an alternative.
Is cow gum still available or are there other substitutes?
Gill
Gill
