Hi
I was always told a coping saw blade should be assembled so the saw cuts on the pull stroke. It made sense to me, as every time I tried to do it on the push stroke the blade would bend rather quickly, or even snap, no matter how much tension I put on it.
But recentely I stumbled upon an entry in Paul Sellers' Blog https://paulsellers.com/2014/02/coping-coping-saws/ where he states that coping saws should cut on the push stroke. That set me wondering.
I started searching for any info I could get, or videos on You Tube, on the use of coping saws, and any I could find mentioned, recommended or showed cutting on the pull (not that there is none on pushing, I just couldn't find it) - except for Paul's, and if you look at his videos where he uses a coping saw shows him using it on the "push" mode.
As I don't dare even dreaming of disputing Sellers know-how, I am now a little puzzled.
So, how do you people use your coping saws - on the push, or on the pull? And why?
G.
G.
