Clean design
GrahamIreland
4 Jun 2015
Nottingham
Hi, just wondering if someone could suggest how this bench top was connected to the legs.
There is a stretcher across the middle, but I don't see a joint for the top.
Graham
    99.2 KB
there are numerous ways to connect the bench tops
Tenons in the top of the legs fixed into blind mortices in the top then glued (Old School)
Pocket hole screws on the inside of the legs
Fixings straight through the top then dowelled/pelleted (that appears how the stretchers are attached)
However you do it the fixings do not need to be completely bulletproof as the stretchers will help to keep the structure square and wobble free
HTH
would suggest blind tenons as above or a stopped groove and glued
Ah yes, thanks for that.
Would a couple of thick dowels be as good as the blind tenons - if the thickness were 2"
Also, yes like the idea of the fox wedges, have heard of them but not yet attempted.
Graham
