Martin_S
Am planning to build a bed for my grandson, had something like this in mind:
http://ecx.images-amazon.com/images/I/8 ... L1500_.jpg
Would appreciate some thoughts:
- I could build the ends and back from sheet or I could use M&T posts and rails. My fear is that it will be a lot more structurally sound made out of sheet and considerably less effort than posts and rails. Any recommendations?
- If I use sheet, I presume I need to use ply as opposed to MDF. What do I need to do to ensure smooth, rounded edges? In the past I have had issues with splintering
- It also needs to be taken apart and moved eventually, if I go the post and rail route, obviously bed bolts on the rails is the way to go. If I use sheet, is there an alternative to screwing together that results in a sturdy but non-permanent solution?
Sorry - just thinking out loud on where to start and how best to do this - all suggestions / comments welcome.
