charnwood........? New to turning - please help.
Davidf
21 Apr 2007
Hi,
Can you help?
What i am trying to do is this...
I am an audio enthusiast.....to cut a long story short I want to make audio support cones with my lathe.
These are going to be roughly 15mm in dia x 8mm high (in new money), although the size/shape could very quite a bit.
To this end I ahve purchased a Charnwood w811 lathe, relatively inexpensively (by necessity).
I was trawling the net to try to find a wood holding chuck to hold the wood when I found some reasonably unfavourable comments regarding my machine.
So, whats the bottom line here?
Have I been sold a pup?
What are your recommendations...should I start again?
I would say I ahve been concerned about the speed (or lack of) of my production from the lathe and tools that came with it....standard Charnwood.
I am working with seasoned oak.
hope you can help!?
David
Hello David and welcome.
Not to sure what your trying to do but they seem small pieces.
I thought Charnwood were a resonable machine tool manufacturer.
I looked at several lathes,including the Charnwood ones,before buying the one i did,mainly through recommendations from the forum.
As for the gouges,are they sharp.
As a begginner i would say that you will need to practice first before you can start turning the items you want.Getting used to the tools and how to use them.Read books,and watch dvds,videos.
I find Oak nice to work.
I'm sure there will be more,better advice soon.
Paul.J.
OK,
Well, thats what Im trying to make. (the cones directly under the speakers)
At the moment i'm taking leghths of oak and turning several cones out of each length.
I'm running into the problem of how o finish a length.
ie i have say six cones on piece but daren't leave less than say 1/4 inch of wood on the machine....it snaps easily and is therefore not very safe.
I was therefore looking at the idea of purchasing a wood chuck for the machine as a means of finishing off each cone....having been produced perhapts 75% from the origional 1 foot piece of oak. (This was where I had go to when I started reading horror stories about my lathe)
Sorry, don't know how clear all this is!
BTW the cones could vary considerably in size (esp flatter) than the ones in the pic.
Any ideas on this very welcome!
cheers for now,
David
Hi David, sorry to hear about your dilemma.
As with many before you, you are finding that wood turning is not as easy as it looks. BUT after saying that, it is not hard once you get a bit of practice in, and one of the best ways is to find someone who can at least show you the rudiments of the craft. Then with a little practice you will be churning out those 'cones'.
The lathe you purchased is not the best around, but should be ample for what you want to do with it. As to a chuck, you'll find that you will have to pay more than the cost of your lathe for even a very simple scroll chuck. http://www.charnwood.net/ProductDesc.jsp?cat=33&stockref=W835
There are other ways to hold small pieces onto a lathe, i.e. 1/ faceplate. 2/ screw chuck. 3/ jam chuck. but IMHO I think they all make it even harder for the uninitiated who is trying to learn how to turn.
Sorry for not being very positive, but it all really depends on how many of these 'cones' you wish to make. If your going into production, fine you could warrant more expense, but if only for a few it may have been better to have found someone to turn them for you.
Just as a thought, have you considered making them in the shape of a pyramid, then it may be possible to shape them with a saw, then finishing them by hand.
I'm not trying to bring doom and gloom onto your endeavour, :) just saying how I see it in my small way.
Good luck with whatever you do, and you will probably find someone else along soon who has some better ideas than I.
I was asked to make some of these cones a few years ago for a specialist hi-fi shop he paid £8.00 a cone and was selling them at double that. It was a nice little earner until his demand dropped off. :D
Thanks for the piicy Dave i see what you mean now.
I take it that you are doing these between centres.
If so i would suggest shortening the lengths of Oak,this will make the length feel more rigid to turn, so you can get say 4 out,allowing a couple of inches either end for waste,and turn your pieces as close to the finished item as you can,cutting almost through each base and top using the nice sharp parting tool,then just saw each one off,and finish by sanding.
I should think you could leave about a 6mm stub on each base and top.
Hope you can see what i mean.
Hopeless at explaining things :roll:
Paul.J.
Hi again,
Many thanks for all the replies.....and for moving me towhere i should have been.
How many do I want to make?
Thats something I cant know for the moment......selling a few on is certainlly a possibilty but for now i'm having a lot of fun experimenting with different shapes/sizes/materials (does that make me really sad? hope not. The differences are actually remarkable).
The charnwood lathe was a complete shot in the dark....e bayed a month ago. I see theres a rather heavier item down inxsouth Devon (I'lltry and get a link). As an example would that be a better bet? Should I perevere with the charnwood for the moment.....maybe lliok tobuying better toools? That was what the seller candidly sugggested.
The suggestion of leaving 1/4 inch of waste wood.....that was always one possibility. I didn't like the idea of wasting the material but I agree it may be the only way. I shall have to get to know how much, or rather how little wood i can go down to before risking it breaking.
Yes, I ought to watch some one. My Mum+ Dad wanted me to do an evening course...I figured if I make thade the project too pedantic......it wasn't going to happen. Thinking today maybe the hting to do is suss out possible instruction video/DVDs?? Any good ones to be had?
Thanks again for the input.......just what was needed.
Will give this some thought.
cheers,
David
Hi David.
Personally I wouldn't bother with the Elu lathe. If all you want to do is turn those small cones you could do it on the Charnwood machine you already have. It's just a case of deciding how you plan to hold the timber, and getting a bit of practise in.
Don't forget it's not the lathe that makes a turner, if you are a practised turner you could make something on a electric drill.
Don't need a scroll chuck for these, and your existing lathe should be fine.
Just turn between centres and finish off by hand.
Make a sanding disc for the lathe as well and you can use that for cleaning up the remaining stubs on the bottom.
Cheers, Paul. :D
TEP":3i3lwgs1 said:
Hi David.
Sounds sensible.
Instruction DVD now on order.
The lathe sanding disc also a good idea.
I did have sanding disc attachment for my drill, can't find it now, would be good to organise another.
cheers,
David
Hi David,
Welcome to the forum. The Charnwood is a heck of a lot better than my lathe so if it were me I wouldn't belt down to Devon to pick up an Elu.
As others have said I think you can do what you want with the Charnwood, it seems to me that I learn something every time i switch on my lathe, practice & technique will get you what you want.
Good luck.
Losos":39xqyhig said:
Hi David,
Good luck.
....thanks
that seems to be the concensus of opinion....re the elu......+ practice.
D.
Practice + sharpness of chisels.
Turning is an art form with a bit of science thrown in - practice puts your artistic capabilities to work, a scientifically sharp chisel is the channel!
As others have said, the quality - perceived/imagined/dreamt/formulated or otherwise - of lathe and/or chisels is not so important. There are members here who've achieved very acceptable results with very basic tools.
Turning sharp is not like carpentry sharp, a new mindset is required - turning speeds of relatively small diameter objects can break UK speed limits at the edges. Imagine leaning out of a car window, with a face protection device on of course!, dragging a chisel face along the tarmac at 30 mph.....you lose that honed sharp edge fairly quickly (DAMHIKT).
There are monster threads on this site all about the thorny topic of aharpening, read enjoy and learn at your leisure.
Which is all a very long-winded way of saying that without sharp chisels you will not have a happy turning experience. So you need to practice sharpening too!
As for the target size for stubs or end bits it all depends on how you hold the wood. If you stay with spindle turning you will need to allow for the wood 'holders' (aka the centres) at either end actually sticking in a bit, but that's all. Again, practice!
Good luck
I suspect this is the major part of it.
I do now have wheel grinder with coarse+fine stones....I'll have look at those threads.....
Thanks vm!
David
Hi
I was just having a around at the other posts sililar to my own....I see a reference to "Keiths Book" re sharpening tools.
Could some one tellme how to obtain this?
thanks again,
D.
