pswallace
Hi folks, I am thinking of putting 100mm castors on A workbench I am building (7' long) . . .Do castors affect the stability of the bench much? Thanks Phil.
CHJ":2sw21mq9 said:On the crude little bench I use I have a couple of fixed hard nylon castors on one end 10mm or so proud of the legs and retractable handles on the other end, allows it to be moved wheelbarrow fashion.
When in use a couple of wedges are kicked under the two legs on the castor end to suit the floor and lift the wheels off the ground and stabilize the bench.
houtslager":ub62imru said:make sure the wheels are high quality ball bearing races and the rubber is a composite one - it grips the floor better DAMHIKT and goes over extension cables / air lines better then the solid rubber or plastic ones.
hth
K
