Bringing old oak door back to life
baldbrummie
19 Mar 2012
Birmingham
Hi, any idea how to bring this old oak door back to life again..for example should I use varnish or oil after sanding .... 1920's how in a conservation area so I need to keep the door
Any help would be great
Steve
    182.6 KB
Sand it, oil it. Must say it looks good as is apart from the bottom greying a little
Coley
I'd be very careful about sanding this. Have you thought about how you'll sand around the hinges, not to mention the bolts and not have the scratches show up? Particularly if you're going to oil this cross-grain scratches will be plainly evident.
I would try a stripper, then use scraping to get any tricky spots.
Well that'll help! Was that a big job? I wouldn't have thought they'd be easy to remove.
Make sure you oil it well where the ironmongery touches it - you'll have blue black stains everywhere otherwise. If you're painting the hinges do the backs as well, bare steel and oak are a no no. (unless you're doing it deliberately of course :D ) For the same reason don't be tempted to use wire wool.
I would scrape it, instead of sanding, please show us pictures when you've finished, that's a nice looking door by the way, you can't beat oak doors.
Steel and oak are not good bedfellows so a good long lasting finish on the steel is as important as that on the oak. I would Galvafroid any bare steel before painting it.
Jim
Looking better now, I've left the lion head door knocker off...it reminded me of my home team Aston Villa :( :(
I couldn't get some of the grey wood to clean up, but I think it adds to the door.
    111 KB
