Bracing MDF to prevent sag - Hardwood or MDF Bracing Materi?
Tetsuaiga
4 May 2012
UK
I'm planning a drum sander to build and thought it would be sensible to brace the mdf which is what the table will be made from. So I thought i'd make some slots to insert bracing into to form a the box which will be the table.
Would it be best to use more mdf or hardwood for the bracing or, I guess ribs is the term? I suppose mdf as it should be most stable?
Yes torsion box looks like what I have in mind. I might only brace across the width though.
I dont like mdf for bracing as it has no 'give' like natural wood or ply. If you for example over drill a pilot hole in wood it invarable is tight as a proverbial in a short time. A hole through mdf is just that. No tightening around the screw. Best wsihes
PS I have used mdf for stair risers and it works but there it is set in a groove.
Good point about screws. I think i will just slot the board edges into grooves instead and I think that will give it enough strength and flatness. I'll either be using 24 or 32mm mdf so should be quite strong.
engineered beams, but scaled down of course should add a fair deal of stiffness to it
