I've finally properly finished my first bowl but had an issue with it not being centered when reversed.
I started with the blank mounted on a screw chuck held in the chuck and turned the outside along with a spigot.
Reversed the bowl and mounted it in the chuck jaws but the rim wasn't running true leaving an uneven width rim.
Is this to be expected? Everything I've read suggests finishing the outside before turning the blank around but this is the second time it's ended up this way.
