Bookcase
lucky9cat
21 Aug 2006
Gosport, Hampshire
I must confess that I haven’t posted for a while and it’s not that I have been totally inactive but rather that I've been involved in other things as well. Enough excuses.
I was asked by someone I knew to build a bookcase to fit a particular space on his landing. I’ve only done one commission before but the price was right so I went ahead and prepared a drawing on SketchUp. He wanted the piece to be plain and functional and done in beech. The biggest worry was the size of it, but we worked out that it could be negotiated through his hall and up his stairway to it’s resting place.
He liked the drawing, we double-checked our measurements and I went off to the wood yard with my (not so happy) dear wife! I got the boards from Goodwillies in Waterlooville for £87. This was priced at £743 per cubic metre including VAT for boards 27mm thick and up to about 250mm wide. I also got a sheet of 8x4 6mm MDF veneered both sides from Bamptons in Southampton for £34. Bamptons were good enough to put 4 cuts in the board for that price which saved me manhandling the thing around! I’d be interested to know how these prices compare with those of others; are they reasonable?
After cutting the boards to just over length and planning/thicknessing them to about 3 or 4mm over thickness I left then to acclimatise to the humidity in my shop for a couple of weeks.
After bringing the boards down to final dimensions I finished each face with my jack plane to take off the ripples left by the planer. I was determined not to use any sandpaper at all!
The first job was to drill the shelf support holes in the uprights on the drill press.
I then cut the groves for the panels on the table saw. Each piece was put through twice, with the wood flipped around for the second cut hence ensuring the groove was central. I was aware I was doing this for a price and hence was looking to save time where possible. I have recently acquired a Record Multiplane from eBay and would have loved to try it out but it would have taken far too long.
Tenon shoulder cuts were done on the table saw. This is an easy and accurate way of doing them that requires very little marking out. I don’t like working with the blade exposed so take great care especially when the job is a little bit repetitious as this is.
Tenon cheeks are cut on the band saw. I aim to cut them a fraction oversize and trim them to fit with the shoulder plane.
Mortices are cut with the dedicated morticer.
The only exceptions are the mortices for the front rails that support the fixed shelves. There are only 4 and it would have taken longer to set the morticer up than cut them.
The front rails that support the fixed shelves need a large rebate cut into the back of them. These were cut on the router table.
A similar rebate was cut in the front bottom edge of the fixed shelves. This can be seen at the bottom of the wood in the vice. A notch was cut in the back corner of each of these shelves to clear the frame.
The panels were cut next from the MDF. I use masking tape to eliminate tear-out when crosscutting sheets. The sheet is flipped when crosscutting so the tape is facing down.
The side panels were then glued up.
I only had enough 6mm MDF for two and a half back panels so had to glue up boards to make up for the missing half rather than purchase a whole new sheet. Another complication was that the client wanted a hole in the back panel to access an electrical wall socket the bookcase was going to cover up. It’s these little complications that take up a disproportionate amount of time. Here’s the “mouse” hole being cut in part of the made up panel!
Here’s the complete panel in the final gluing stage. As can be seen, it’s made up of the scraps, some not even the full length! It was glued up in sections.
As I haven’t made a cross-cut sled for my table saw yet, to cut it square to the long grain I used double sided tape to attach a large square which was referenced against long grain.
I then rebated three edges to enable it into fit the frame grooves. This was done on the router table.
The forth edge also needed a rebate to accept the MDF to which it is glued. I really should have bought myself another sheet of MDF and saved myself the bother – this all took ages!
The major glue up. I did this in two stages. With one side panel on the floor, the back rails were glued in place, the panels put in and the other side panel put in place but not glued. The fixed shelves were put in place to hold the assembly square.
After removing the clamps, the un-glued side was taken off and then glued back in place. The double garage was beginning to get a bit tight for space now and this really was quite tricky. Without the help of my dear wife I couldn’t have done it!
It was now clean up time. I confess to using the random orbit sander here. How do you clean up a mortice and tenon only using a plane? Notice the cleats in place to hold the bottom shelf.
Here’s a detail shot showing how the fixed shelves are supported by the framework and the rabbit in the front rail.
My dear wife now asks why I didn’t build it in two units. It is big and I’m worrying whether it’s going to get up the stairs! It’s hard enough moving it around the garage! The fixed shelves were glued firmly to the front rails with only a spot on the side frame rails. This should eliminate any movement problems.
The skirting and architrave have 15 degree bevels on their top and bottom edges respectively, which were cut on the table saw and then hand planed smooth. The mitres are cut on the table saw being careful to cut both sides of adjoining corners on different sides of the table saw blade. This should compensate for any deviation from 45 degrees the blade might be set at. All of the pieces are glued to the frame work. The top, which is made from the 6mm MDF was pinned on before fitting the architrave.
Detail shot of how the moveable shelves are held in place.
It’s finished with two coats of Danish oil and two applications of beeswax.
With all of it’s shelves.
Quite to everyone’s surprise it was a breeze getting it up my clients stairs and into place.
The client absolutely loves it so I’m happy. It was my first project in beech and I was really surprised at how much easier I found it to work with than oak. I was pleased with being able to hone my skills on the hand planning. It really was worth the effort as the finish is superior and I hate sanding!
Cheers, Ted
Nice work Ted !! :)
I'm interested to know the difference to work with beech than oak ?
Rich
Rich,
Beech tends to be pretty straight grained and less knotty.
With oak, I've found that the grain can switch direction when going up and down a board. Putting a piece through the planer in one direction will give you tearout in one place, reverse the board to see if it resolves the matter and you may get tearout in another place. With some of this beech, I could put it through the planer in either direction and get no tearout at all.
Beech also appeared to have a tighter grain, in that when hand planing the shavings held together better whilst oak appears to produce stringy shavings.
That's what I've noticed but I don't claim to be an expert. Any one else like to comment?
Ted
interesting ! Thanks Ted
I used mainly oak. occasionally some ash , mahogany and wallnut
its always good to know how other woods 'work'
Rich
Ted
A well executed and well documented project, resulting in a fine bookcase.Will it be fixed in any way or free standing, as with its height and relatively narrow shelves, stability may be a concern.
Dennis
Ted
Hi Ted
Nice project - i've got something similair to make as a room divider - i'll show SWMBO your project and see what she thinks!
On the Oak/Beech issue, I can only say that my experience matches your own. Some planks of Oak are fine, but others have grain reversal which can cause serious tearout.
Karl
Dennis,
Thanks for your kind comments.
The bookcase sits very firmly by the wall with a very slight backward tilt (if anything). I was prepared to put a couple of thin wedges under the front corners to increase stability because sometimes the carpet grippers put around the edge of a room can cause stability problems.
The design is based on a bookcase made by Old Charm that I purchased many years ago, but scaled up to the clients dimensions and left off the fancy bits. That's why I didn't think twice about stability problems. Looking at the pictures of the finished piece, you make a good point though.
Ted
Lovely work, Ted. I wouldn't have the room to stand something like that upright in my workshop! :D
I've been taught not to sand near a mortice where the shoulders of the tenon will meet, as you run the risk of making a mess of the joint. Planes are preferred because they tend to take a nice, even flat, square shaving... I can't see any obvious fault in your workmanship though! :wink:
I agree with your points on beech against oak, much easier to work with. :)
Lovely craftsmanship. I like how you don't notice the difference between the fixed and moving shelves, a good way of increasing the strength without compromising the design.
Ted, nice job. Agree with your Oak v Beech, however I think Oak is more interesting.
Thanks for the further comments.
I'll try it with the plane next time, Olly, but it must mean being pretty careful not to catch the adjoining bit of wood and taking a cross grain shaving off it.
One other thing about the beech that I forgot to mention was that the 27mm 10 inch boards had enough cup in them to be a problem trying to arrive with a flat 22mm board for the shelves. I ended up having to saw them in half lengthways, plane them and then rejoin them. Generally, this is no problem with quatersawn oak.
I must agree, Newt, that I find oak more interesting but when I priced this, the only difference I allowed for the oak option was the difference in the cost of the wood. So I'm glad he chose beech. :)
Looks great, I wish i had the room in my private workshop to make something like that!
As for sanding mortice and tennon joints........ Im only speaking now from using M&T's in window & door frame making, but a belt sander generally gets the joints flat with care going with the grain, and then orbital sanding. Obviously though, windows are of a less quality finish than furniture.
Sorry Ted, I misunderstood what you mean. :oops:
It sounds as though you're talking about cleaning up after the assembly. Well, you can probably plane the joint flush with care but, even if you do use sandpaper or a sander, the danger is still that you will be working across the grain on the adjoining piece. Or, if you're really not carefuly and spend too long sanding in the same place, you'll create a 'dip'... DAMHIKT :oops:
