BLUM Tandembox Drawers
Shultzy
10 Oct 2006
Near Lichfield, Staffordshire
When I make drawers I usually complete the drawer box and fit the runners to the box and cupboard sides. I use thin packing pieces to position the false front accurately and then glue and screw through the handle holes. This time I'm buying BLUM Tandembox drawer fittings. My question is can I still use my method of construction or should I only make the base, back and front and rely on the adjustments in the Tandembox to make all the fronts line up? Are there any other tips to making a "spot on" job?
Use your same method and then if the fronts do need tweaking when the unit is all in position and weight in the draws use the adjusters to fine tune things.
J
