I properly popped the TS55's cherry over the past few days with a slightly dirty venture into 4 cuts of OSB (did it very slowly at 3/4 speed on the saw as per the book) which it made beautiful joints with :lol:, and then broke down an 18mm and 12mm sheet of MDF, then a couple of sheets of 12mm and 6mm ply.
All taken nice and slowly, few mistakes along the way like forgetting which side was "the good side" so 2.2 mm shorter :lol:
I've noticed that the side of the blade and parts of the teeth that aren't TC, have a slightly sticky coating. I assume this is glue/resin, if that's the case, what do I do to remove it and how often should one do this?
