Wood can be blackened in a host of ways.
Because you can't see this closely it could just be painted! Two or three thinned coats of black paint goes a long way towards producing a very nice 'in the wood' black look, even though it is just a surface coating. Coloured shellac, varnish or lacquer can be used similarly.
Obviously it could be stained too, aniline black dyes can work excellently on a range of timbers. Once you put a film finish over this it doesn't look much different to if you'd just use thinned paint, but if you oil the wood instead you'll see more of a difference.
Because it's oak it could have been chemically blackened by a method now made famous by the Internet, using "iron-infused" vinegar. You can make this just by dissolving clean steel wool in vinegar, sieving it and then painting it on the oak. This reacts with the tannin in the wood, turning it grey through to black depending on the tannin level. So this can be highly variable, but results can be evened out using a tannin solution of some kind.
Last but not least if you have access to sulphuric acid that can be used to blacken wood. I've only seen this in books, never in the flesh, but it looks like it produces a jet black and it's deep in the wood, so the piece can apparently take knocks and scrapes without revealing pale wood as easily as other methods.
