YorkshireMartin
Hi all,
I'm struggling to decide on the support form of my bench. It needs to seat two adults, possibly three.
My original idea was to use a single piece of 25mm thick 250mm wide walnut for the top, then have 50mm square legs inset from the ends and tenoned to the top. Joining the legs together would be some 20mm walnut, as a full leg height stretcher meaning the span of the legs is around 200mm. The leg stretchers would be set into a dado cut in each leg.
On top of that, I was to use a maple stretcher (20mm x 100mm) across the length of the bench, which would be tenoned through the full height stretcher in the legs and flush with the top of the legs, enabling the top to be glued to the width stretcher, leg stretcher and the leg tenons. Phew, I hope that makes sense, so hard to explain.
Now I'm thinking that a seating span of 1,500mm requires a central support or, if you'll pardon the expression, a third leg. :lol: #-o
The span of 1,500mm is full width, i expect the inside distance between the legs (if two are used) to be around 1,000mm. Is the maple stretcher alone enough to support this?
Racking forces are also a concern as with a 25mm thick top, I'm limited in tenon length on the legs. Thickness limited too, as the legs are only 50mm square, giving a tenon width of approximately 16mm. I want to avoid a through tenon, for aesthetic reasons.
Considering adding a second stretcher lower down to counter the racking force.
It would be great to hear opinions.
Regards,
Martin
Regards,
Martin
