I have an old "ish" (25yrs) B&D professional 6" bench grinder that has served well for all that time, but the wheels have reduced to less than 5" so I decided to get a new wheel for the fine finish, I got a 120 grit wheel and although it came with a slightly oversized bush, I was able to knock it out and also the old wheels bush and refit it to the new wheel, and it is a nice snug fit, I mounted the wheel between the two clamshell washers and turned it on, and was a bit gutted to see it wobbling, not just back and forth (which I can dress out easily enough) but also from side to side, at first I though I must have a dodgy stone, but after removing it all, carefully cleaning the clamshells and remounting it, it was the same, so then I tried putting the old wheel back, and now it wobbles too! I am at a bit of a loss to figure this out, I can only think that the Clamshells are poorly machined because I can think of no other way it can go off centre like that, is this a common experience?
I am therefore thinking of replacing the whole thing, choices seem to be between an Axminster for £50 odd, or Record Power 6" for similar loot, an 8" for £75, or even further upmarket for a Creusen at £170 (the cheapest I could find so far at least)
I imagine the Creusen is by far the superior bit of kit, but does it convey a significant advantage over the others?
Given a choice between the first three only, what would you go for?
Anything I may have missed when it comes to refitting the wheels, after all, if there is a set process that does get them centered I may save myself some loot!
All replies appreciated, I have been turning for all those years, but this is a new one, we are always learning!
