Jacquiemalta
Hi,
I recently posted about finishing my beech tabletop. I have decided on the finish so all is well in that respect.
However, the wood got dented somehow so following advice online, I steamed it out. It has come out well but after sanding with both low and high grit sandpaper, the surface has gone kind of shiny and I'm concerned the stain won't take the same in this area. I block sanded the area with 80 as the area surrounding the dent had raised too of course. I then sanded with 120 to get a decent finish.
However, the area has now gone sort of shiny. It improves if I sand with 80 again but I want to use a higher grit to get a better final finish of course. The best description - the wood looks kind of polished after using 120 and no more dust comes off.
I was thinking about maybe using an electric planer to remove the top surface of the whole top but after reading forums about using an electric planer (which I have but have never used), I realise that is the last thing I want to do; there is no doubt at all that I would make it a lot worse.
Any suggestions please?
