noddy67
I'd be interested in peoples workflow with regards to cutting a number of slices of veneer from multiple boards.
My assumption is one squares up all four sides of the boards, places one smooth face against the fence to make the first cut and then runs the board that now has one band sawn face through the thicknesser to resmooth (a word?) that face and then repeats the process until the board is all sawn into veneers.
My question is in order to use the veneer in a book match arrangement for example one is going to have to smooth off the rough surface of one (or both) of the veneers or are people getting a surface straight from their band saw that is smooth enough to glue to the mdc substrate. How do you swooth the rough side of the veneer if necessary? I realise that I can glue he planed side of the veneers to the substrate but that limits layout options.
I suppose I'm asking what are peoples specific (and hopefully efficient) work flow from solid board to glued up veneered panel.
Hope thats reasonably clear.
