Hello all,
I was wondering if anyone had any experience with the Axminster TH410 thicknesser? There seems to be limited info out there so trying to decide if its a good purchase is quite difficult. I currently use PAR timber so just need to get it down to size but will look to get a surface planer down the line.
I like that you can fit a digital counter, but don't like the absence of micro adjust blade screws/quick change blades etc making blade changes a huge faff. I'll be doing quite a bit of thin fine stock too so if anyone can chime in on quality of cut/whether the rollers leave tracks or not would be great.
Pros;
Wide capacity (i make a lot of trays so this is good)
Quite well powered
Digital counter option
Can process stock as short as 200mm
Cons;
Price, seems to have jumped up recently I think, as has other Axminster stuff
Blade changing
No idea on what the finish is like
I need it ASAP and Axminster delivery times are fairly long
Other option is to just get a Startrite SD31 P/T which seems to be good bang for buck, but again thats a bit of an unknown entity or theres a nice looking Cooksley thicknesser on the bay but I have absolutely no knowledge on that whatsoever.
Or someone could sell me their TH410 2nd hand for cheap any info is much appreciated, cheers!
Pros;
Quite well powered
Cons;
Blade changing
