artanddecco
I have an Axminster K10 Chuck Package including Screw Chuck, Faceplate and C Dovetail Jaws. Because my lathe is the Jet 1220VS I will mainly be working on a variety of small size projects. I plan to make a plate (6 to 8 inch diam) , convex on both sides, and fit a mini clock in centre drilling the recess with a 35mm forstner bit. When I turn it over on its second side, after drilling the the first side with forstner bit, I thought that apart from a jam chuck, for holding it in the headstock, a set of small BF Gripper Jaws would be ideal. When I mentioned this to my class instructor, he asked if I had considered the O'Donnell Jaw Set, although more expensive, maybe more useful for a variety of other jobs. He had not used them but heard good reports, and likewise, checking back on this site, some of you do most of your work on them. My questions are (1) There are three different size jaws in the set, does this mean unscrewing the dovetail C jaws each time and replacing them with either of the three O'Donnell jaws or the BF Gripper Jaws if I decide to order the latter. (2) I think the BF jaws will be ideal for the job mentioned above, but will the O'Donnell Jaws be equally as good and more usefull ? what other applications can they be used for. What do Axminster mean when they say they are spigoted together. They do not say if they are gripper jaws, ie for non dovetail work, or dovetail jaws or both. Advice and suggestions welcome.
Have only had my lathe for a week, so have a lot to learn
