bogmonster
Hi,
I am considering either buying or making some cole jaws. Today I mostly use a vacuum chuck or very occasionally a doughnut chuck. On the outgoing lathe I had very limited clearance over the bed and issues using the bango over the bed (complicated so wont bore you) so rarely used tailstock support. I will continue with the vacuum chuck as I often do natural edge and it works really well but was also considering either making or buying some cole jaws.
To this end I have a couple of questions:
1) Will the new evolution chuck provide enough travel so there are no 'dead spots' on the Axminster cole jaws like I believe there are with the SK100 Clubman chuck?
2) Will they fit over the bed (technically I think they will) and allow enough clearance for adjustment? I fully expect I will need to either remove the chuck to insert the jaws or swivel headstock away from bed. I ask this because Ideally I want to use the tailstock for additional support. Based on the stated specs I suspect not. The swing is 4006mm which only leaves 6mm, not enough for adjustment
Just wanted confirmation?
I think this leaves me with the option of the 150mm wood jaw plates, some ply and some buttons - although I hope to find some cheaper buttons than the Axminster ones.....
BM
BM
