WoodMangler
Gentlefolk,
I have an old wood lathe I picked up at a local auction for a fiver a couple of years ago, and I'm finally getting round to putting it together. I've found a maker's name 'Arundel', and a look at the 'lathes.co.uk' site indicates it's an 'E5' model (http://www.lathes.co.uk/arundel/index.html about 1/2 way down). It's a bit rusty but I don't think there's anything disastrously amiss with it - although I suspect that getting the faceplate off, and shifting the centres in the headstock and tailstock might yet prove me wrong... (Edit: To my surprise, they all proved easy to remove.)
I do, inevitably, have some questions...
1) It has a 4-step pulley in the headstock, but I don't have the corresponding pulley from the motor - can anyone suggest a likely source of such a thing ?
2) The headstock spindle spins smoothly with very little lateral play, but has a considerable amount of along-axis play - how do I adjust the thrust bearing ?
3) What's the best oil to use in the wick-feed oilers for the plain bearings ?
4) Does the separate bowl-turning attachment ever appear on the open market, or are they like hen's teeth ?
5) Is there a manual or handbook available for this lathe ?
I've tried to attach a couple of pictures, one of it's general condition, and a detail of the headstock pulley.
