I'm in the process of stripping an oak (not pine! ) engineered floor. Done all the hard work but the variations in colour of what I'm guessing is White Oak is perplexing my tiny brain. I bought Osmo filler (I have the Osmo satin finish to apply). The floor was previously coated with a coloured finish so a bit of guess work was involved as to what filler I would need. The filler seems very user friendly and first impressions are good. I've used some where the wood is light and it's a good match but theres knots and so on where it will stand out like a sore thumb. You can apply a colour after but I think that's going to lead to all sorts of problems with bleeding etc.
I have a bottle of dark oak stain, would it be madness to mix the stain and filler in small amounts pre use. Wouldn't take much, I don't have huge areas to fill but they vary in colour from area to are depending on board colour. What I was thinking was adding a few drops to the filler to darken it up as needed. The filler is water based and instructions say you can add water to thin anyway.
I might have been on too many HSE courses about not mixing chemicals! 10 years ago I'd have just done it but I can't afford to have the filler crack after 6 weeks because I added something other than water.
Is this common practice or madness?
I could buy some darker Osmo filler but I'm on a tight schedule. Two young kids and an unfinished floor don't mix well! Need to get that final coat down asap.
Cheers as always
Chris
Cheers as always
Chris
