RogerS
I access my email via IMAP using either Apple Mail on the desktop or K9-Mail on the Android phone. All works fine apart from one niggle that I don't understand.
I set up Rules on Apple Mail to move incoming emails to specific folders. For example, email notifications from UKW from threads I have subscribed to, are moved (filtered, if you prefer) to a folder called UKW. Then it is a simple matter to periodically Select All and delete. So far, so good.
However, I noticed that these notification emails do not appear in the Inbox on K9. Digging in to the actual mail on the server using their webmail interface shows that those moved emails have been marked as 'Marked as deleted'. I presume that Apple Mail gets in ahead of K9 - moves the email and this results in the email being flagged and thus invisible to K9.
Temporarily turning off the rule proves that (a) notification emails are no longer moved ...as one would expect (b) notification emails become visible on K9 (c) they are not 'marked as deleted'.
Why does moving the email result in 'marked as deleted' ?
Second question. If I go into the inbox folder using webmail and change the email as Undeleted - it shows up there in webmail as a normal email but I cannot see it - either in K9 or in Mail. Is this because there is some hidden syncing mechanism and that the mail clients say to themselves (a) I've already got this email and moved it to a new folder (Apple Mail) and (b) I've already looked at this and it was deleted so I'm not showing it (K9) ?
TIA
TIA
