Thanks Paul, have a lot of stuff lying around that must be shifted but I'm afraid it's all going to be of a simple form nature so must try harder to get the 'balance' right.
Kim the undercut is very slight, did not know quite how to finish the rim but the wood looks so busy it just seemed best to leave well alone and I think a tendency to undercut always makes the transition look sharper than constant thickness.
John, most of these burrs seem to be quite hard once dried out, and that can take years, but they inevitably have softer spots or cavities. This can be quite challenging on the tool control front to stop unwanted bounce.
In general because of the interlocking nature of the wood growth most times you create dust rather than shavings. If however you get your turning tool sharp with the correct angle of attack etc. it is possible to have the pleasure of seeing long but fragile shavings streaming away.
It's just a case of whether you aim for the pleasure of seeing this achievement or just getting the job done, not always mutually exclusive.
Wood density (weight) can be strikingly different but in the main I've found them to be heavy.
Finish off the tool due to bevel rubbing is usually very good, requiring little sanding.
