Hello Sheptonphil,
The lathe Ax AT1628 V/S well what can I say.
Bad points first.
Have not found any bad points as yet, some little foibles but have got round them all easily examples of which are thus. I would prefer the magnets in control box to be a little stronger mine lands on the floor a little to often and only a bed of shavings to land on saves it from potential damage. Attached an elastic band as catch me strap.
The airflow from the motor passes directly behind the headstock heading for the tailstock disrupting dust extraction considerably, so I made a thin plywood baffle to redirect this airflow it works fine no more problems.
I find the Ax tech spec quotes low gear min speed as very much lower than the 66Rpm I can achieve or the motor gets very stuttory.
The (As someone else pointed out) Digital speed read out covering is very very easily scratched by dust. I cover it with cling film now and its no problem.
The toolrest supplied with the lathe for me and the type of work I do it was way too long. I had an engineering mate construct me 2 new toolrests one 5 inch and another 8.5 inch, so no more problem.
Good points are too many to list realisticaly but will give it a go.
Superb smooth power and loads of it and fantastic torque even at lowest possible speeds in both ratios.
Its also utterly brutal!!
Further explanation needed here.
I still find it a little scary, I was used to a CL3 which I am now learning was quite a forgiving little machinre.
I am getting used to it and I love it a little more each day, I have in places quite radicaly had to alter the way I work with the lathe to achieve best results, these best results now exceed my capabilites on the record any I wouldnt dream of going back.
I think its a superb machine I have already clocked 70 plus hours and completed much work including some 15 inch birch bowls. I find gladly each day that my capabilities get a tiny bit closer to matching the machines capabilities and one day I may be its equal.
Im off on a whimsy I know but you did ask.
Cant think of anything else to say (Thank the lord say you) Lol.
Take care.
posting.php?mode=reply&f=6&t=75781#
All best. Rend.
