Hi everyone
I need some advice on best materials to use on a box gutter. The gutter will span a 170mm gap between two houses. 1 edge will fasten to a gable end wall and the other edge will attach to ptiched roof, underneath the lowest course of roof tiles, probably to a roofing baton.
The overall length of the gutter will be approx 8-10 meters.
So far I have taken advice for the following materials:
1. marine ply covered with rubber and then a layer of rubberised Plygene
2. Aluminium
3. Coated galvanised steel
4. PVC
I have just seen advertising for fibreglass guttering too.
I am not a builder but I will be asking my builder to install the box gutter and have it pre-fabricated in 3 sections with end pieces. I assume whatever material is used it needs to retain some flexibility since I cannot guarantee the trueness of the walls and I know the gap between both properties isn't likely to be perfectly consistent over 8+ meters.
Any advice appreciated.
Mark
2. Aluminium
4. PVC
Mark
