Good Surname or what ?
I plan to make the desk top illustrated above. The dimensions are 750mm by 450mm. I'll probably finish this to 35mm thick.
The problem is I am short on timber. The 2 outer boards will need to be made fom 2 pieces each and joined end to end. I'm hoping that the long grain join to the centre board will provide sufficient strength.
To disguise the end grain join I propose to insert a 6mm wide band of a contrasting timber and then rout decreasing depth/length channels in both the top and bottom surfaces which I'll also fill with the contrasting timber.
Given the issue of joining end grain should I use a dowel to add some strength - passing this through the 6mm filler?
And before someone suggests buying more timber - I'm trying to use up some bits before SWMBO notices how much I've got!
thanks
Phil
PS - see some of you on Sunday I hope.
