Colarris
My sawing/marking was a bit poor and some of the tails are a little wide, stopping the joint from fitting snuggly. Whats the best technique for reducing the size of the tails slightly?
Or to put it another way - cut the pinholes first, then the pins. The "dovetails" are a secondary feature - just the wood left behind between the pinholes.Peter Sefton":342a33xr said:I know poeple have different ways of cutting dovetails but for me always cut the tails first for through or lapped dovetails they should be finished off the saw then scribe around them to make the pins. Never retrim the tails - any fitting should be done on the pins if required. ....
Pete's correct here...whatever you do, don't adjust the tails. Adusting the pins with a sharp chisel is much better as you've generally got more room to work and the shape of tails won't be affected - RobPeter Sefton":23pn51as said:I know poeple have different ways of cutting dovetails but for me always cut the tails first for through or lapped dovetails they should be finished off the saw then scribe around them to make the pins. Never retrim the tails - any fitting should be done on the pins if required. If you are making double lapped or secret mitred dovetails, cut the pins first.
I hope this video might help http://www.peterseftonfurnitureschool.c ... ng_videos/
cheers Peter
