• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Found Abwood vice handle
ormandge
21 Aug 2021
Cardiff
Hi all!
I've taken possession of an Abwood 4" tilting and swivelling vice, which has no handle. It's a square drive, measures 14.4mm, so presumably a 9/16" or 5/8" drive handle would suit? Anyone got anything?
Ta!
Have a look at the Model Engineering website, machine tools advertisments....
or...
homeworkshop.org they are just a used tooling website for hobbyists....bit like ebay.....
5/8" nominal will be a bit sloppy on a 9/16" square. Make that combination out of cardboard and see how much play there is before spending your cash. A considerably bigger one is easier to shim down to size than a slightly bigger one.
'Crank handle' on eBay with suitable filtering will find something:
Cranking rotating handle cast iron new | eBay (DIY square hole)
Machine Vice Cranked Offset Handle, 3/4" (19.2mm) Square Drive Hole | eBay (Shim down to size)
RS have new ones, as do Zoro:
ELESA Crank handle-DIN 468-80-B8-F DIN 468-80-B8-F| at Zoro (See DIN reference - using that as a search term might bring useful results)
https://uk.rs-online.com/web/p/crank-handles/0237299 (This is the easiest option as a few strokes with a file will make it fit).
9/16 af socket?
How would you fit a 9/16" hexagon or bi-hexagon socket over a SQUARE shaft of the same AF dimension?
Large hammer and red heat?
An 18mm AF 12-point socket would, however, be quite close and not need percussive methods.
RS PRO Steel Revolving Crank Handle 125mm Radius | RS (This is the easiest option as a few strokes with a file will make it fit).
Thanks for the reply - this is absolutely spot on!
Senior moment! Ooops 🙃
You used to be able to a 5/8" eight point socket (Britool) but not made anymore. the Americans are still makeing eight sockets probaly expensive with carrige etc
