Hello,
I have bought a Dick rabbet block plane recently. This is a small review.
The plane is hefty and well finished, the inside has a pale brown coat of paint/powder coating. the sole is flat. Sides are square with the sole. The adjuster has a quarter turn of backlash. Mouth opening is under 1 mm (it is between 1 and 0,8mm, depending on the cutting depth). The cutter is finely ground and flat.
My only objection is about the working of the adjuster and lever cap, as the tightening of the lever cap diminishes the set cutting depth, so setting the cutting depth is guesswork.
Otherwise the tool performs well.
Have a nice day,
János
Have a nice day,
János
