gasman
With my apologies to everyone who has 'been there, done that' with james Krenov - I have not yet and have just read his 4 books which I found truly inspirational.
FWW has quite a few Krenov-style cabinets so I started out with my trusty 'thinking book' and sketched a couple of ideas
Then decided I definitely wanted a curved front - so played around with some ideas for that
I wanted the front of the base and the doors to be curved - so I made a gentle laminated former from a bit of 4x2 and got thicknessing!
For timber - I decided the top would be more of the beautiful ripple sycamore which I used for my backgammon / chess table
Whilst for the base I have just got some beautiful cherry from a mate who cut a tree down a couple of years ago which we had thicknessed and has been in his garage stacked
I started with the cherry and cut thicknessed and laminated 6 pieces of 4 mm cherry before glueing up to make the curved front. The legs were made from 45mm square cherry using a plywood template and a flush trim bit followed by planing / card scraping
Here is the base clamped up (but not glued up yet as I may want to reduce the width depending on how the doors go.
I am interested in what people think about the use of dominos.... Krenov liked dowels and also I am sure I have seen a couple of articles alluding to the use of a domino in later years. Any thoughts?
Here are the curved legs
Onto the doors
I found some lovely ripple sycamore and cut the rails. The 2 inner rails stop short of the stiles a la Krenov so that the stiles which are paired, extend across the 2 doors. The stiles are also laminated and curved to match the curved front of the base
I used bridle joints which were straightforward for the rails but which for the stiles I cut freehand on the bandsaw and then tided up with a thin very sharp chisel
I also wanted a muntin for each door - which are 12.5 mm wide and 15 mm deep with a 3mm slot on each side for the glass.
I am absolutely loving this - first proper job of the year, days getting longer etc etc
Thanks for looking. Comments welcome
Mark
Onto the doors
Mark
