Don't laugh too hard if you can help yourself...
So you typically but hardwood in nominal 1", 1.5", 2", etc plank thicknesses, but what do you you do if you want to end up with a 1/2" board?
Is it the case that you simply thickness a 1" down, essentially throwing away a lot of your wood as dust, or do you resaw 1.5" on a bandsaw and then thickness down each half? In which case isn't the resaw a tricky process?
I'm at the stage where I've been teaching myself hand techniques but I realise that I need to get some machinery to get to the stage where I can build properly. Don't want to have to rely on a woodyard for everything, and I need to work out the minimum machinery I need to build furniture.
