gmercer_48083
I am making a molding plane and I would like to find a 7/16" diameter round file. Ideally it would be the same diameter from end to end, and have a fine cut (like a chainsaw file). So far the closest thing I have found is a rat tailed (tapered) turnip cut (quite coarse) in a 3/8" diameter. I have used the rat tail file as much as I dare, and now need to refine the iron.
A half round would also work... But I can't seem to find a listing where it shows the radius of the file.
I am using the file to shape the iron which is O1 steel. I need to sneak up on a 1/4" radius (1/2" dia.) while shaping the iron, to match the profile of the plane.
"If anyone knows how to describe the file I am needing, I would be grateful".
