I have the plate of what was once a quite ordinary gents saw, 10" long, .5mm thick, 13tpi, filed rip, set from origin at 1mm, which I want to put to use.
On looking closely the rake angle seemed somewhat high - actually at first sight I thought, "heck, 30 degrees!", so I took a macro picture and measured the rake on several teeth. It is 24 degrees.
I searched a bit in my books and in the net and this does not seem usual at all, even though I found several references of up to 20 degrees, and I seem to recall one (but just one) mentioning up to 25 degrees.
What kind of work are 24 degree raked, rip filed teeth used for?
