1.5mm divided by 16 = ?
woodfarmer
10 Sep 2013
poitiers
before you run to your calculator and arrive at a little under 0.1mm let me tell you the context of this mathematical problem.
I am in the process of making a watering system for the greenhouse as the ginger and sweet potatoes need to be kept reasonably moist. So I have hose with 16 by 2mm holes to feed the plants, and infilled the connector and need to drill a hole through it that is big enough to supply a trickle of water at about 2 ish litres and hour, but can vary this by an order of magnitude. What I don't want is jets of water, but a steady trickle or flow.
My original holes were a 3.5mm in the supply and 16 by 1.5 mm for the out flows. this was wildly wrong. I re drilled the 16 1.5mm holes to 2mm but this was still far too small.
ATM I have a 1.5mm hole for the supply and still have the 16 by 2mm holes for the outflow. still too much water flowing :(.
do you get too much all the way along the length of pipe ?
personally, I would go high tech and tape over a few holes :) or maybe just turn the pressure down - I assume this simply connects to a tap ?
Hi
Rather than using hose why not sink reservoirs close to the plants and water via capillary action wicks? - you could always use the hose to re-fill the reservoirs.
Regards Mick
Yes, too much flow from all 16 x 2mm outlets all fed by a single 1.5 mm inlet ??
Think I will add another length of hose to double the number of outlets.
Fit an inline valve between the 1.5mm supply and mains tap to reduce flow and pressure, something like this:
You can always fit more than one, if one doesn't reduce the flow/pressure enough.
and they're usually quite cheap, about £4 - £5 each
+1 XT500fred - just sounds like too much pressure given the diameter of the inlet hole
Spindles idea is also good though and encourages root growth down - useful if you're growing to plant out later
My post disappeared - I assume you've looked at buying a leaky hose?
Your flow rate would be more controllable if the hose were fed from a butt rather than on mains pressure.
How about using a small header tank fed by a ballcock valve? (Think lavatory)
You could then fit a water butt tap, or similar, on it to adjust the flow which would then just be gravity fed in terms of pressure.
Spindle":2esgl7ky said:
Hi
Regards Mick
because then I would have to spend an hour filling the reservoirs in 37 degrees C. Would prefer to just turn on a tap for a while.
Thanks Fred, it is what I thought the feeder hole would do. I have restricted from 15mm diameter to 1.5mm which I expected to be more than enough :(
woodfarmer":2e4c6djn said:
Spindle":2e4c6djn said:
Hi
Regards Mick
So you're not just growing it, you're farming it? :)
Hi
So you can't align the holes in the hose with the reservoirs and fill by turning on the tap?
Regards Mick
Spindle":3bxie5jo said:
Hi
Regards Mick
It is surprisingly difficult to point the outlets in any particular direction, i am using bits of stone etc to stop the sqirting away from the plants. Thin g is a one litre bottle or such is just not big enough, expect to drop 4-5 litres per plant.
