Moderators: Random Orbital Bob, nev, Noel, Charley, CHJ
 Reply
By JimiJimi
#1212666
Hi all
I am working on a project where I need to paint not just the faces of puzzle pieces but the inside and outside edges as well. My problem is that I don't think the pieces will fit back together again. Has anyone else faced this problem? What did you do?
Jimi
By JimiJimi
#1212673
I have thought of using the kerf from a larger blade but I don't think I will be able to accurately make some of the intricate turns. Also, as I am using birch ply, the edges are quite dark so I don't think spray painting will cover it - unless I do several coats, which will bring me back to the original problem. I am thinking maybe extra sanding - possibly with a dremel - but I think it would be a bit hit and miss.
User avatar
By linkshouse
#1212903
Regarding the problem with sharp turns and larger blades, you could get around this by using the dreaded spiral blades. I say dreaded because I really can't get on with them but this is exactly the sort of project that they're made for.
Regards
Phill
By JimiJimi
#1213086
Hi Phil
Thanks for the suggestion, but I too hate spiral blades! I have used them on a couple of pieces where the wood was too large for the saw. I may try a slightly larger blade.
