Moderators: Random Orbital Bob, nev, Noel, Charley, CHJ
 Reply
By rob1713
#1194678
I was lucky enough to aquire this little infill plane yesterday. To my eyes, It looks to be user made. The infills look to be made from mahogany and it is fitted with a Ward iron. It's in pretty good shape apart from a crack in the front infill.
I know very little about these planes so I would welcome views on its origins and age. I plan to make this into a user so I would also welcome advice on how far to clean it and thoughts on removing the front infill to stabilise the crack.
Rob
By D_W
#1194689
If you can get the infills out just by removing the screws, that's what I'd do. Generally, you want to do that to clean them, anyway.
You can do whatever you'd like to the metal then. I always go with less is more, but given that it's not an early norris jointer, it doesn't really hurt the value much to clean them properly.
my preference for heavy cleaning on metal is a deburring wheel and then some wet and dry to make for a uniform surface, but there may be enough pitting on that to make you want to do more. A wire wheel is also fine, or if you're looking for toruture, a wire brush.
It has a fabulous very long ward iron but I'd speculate from this distance that the cap iron might not be ward (that doesn't matter if the cap iron is a good shape). The proportions are nice, and the handle angle is very good - it should be an excellent user. If it is a user made plane (perhaps from parts) the woodwork is better than most user made planes.
There's enough of the horn left that I'd probably clean up the top and leave it as is. It's important for some horn to be there for use (so that you don't have to have a tight grip to lift the plane), but I think there's plenty there for that. I wouldn't top it and add another non-matching piece. The crack on the bun is not structural, I'd fill it (burn in shellac if you have it, or filled CA (filled with a matching dust).
Do you intend to also refinish the infills?
User avatar
By custard
#1194699
I wonder if the front infill is possibly a later addition? The rear infill looks like Rosewood but the front infill might not be. Plus the shaping on the front doesn't look as accomplished, there's a flat spot on the top and that little curlicue on the side looks like a bit of amateur whimsy. Just a thought.
Still a cracking find. The turks head screw suggests Edwardian or earlier, and personally I'd rather have that as a user than pay three or four times the price for something with a mangled and misbehaving Norris screw adjuster.
By worn thumbs
#1194725
Nice looking plane and it represents a lot of work from the maker.I am a little surprised that the metal sides have been made so low near the throat as this would invite a breakage if the plane ever fell off a bench.
If it was mine,I'd just Scotchbrite the metal and sharpen it-then enjoy it.
User avatar
By AndyT
#1194727
Don't rush to do anything irreversible which you might regret or which might make the plane look worse or perform worse.
There are lots of good threads on here showing different degrees of "restoration" which can range from light dusting to aggressive surface removal.
He's not posting at the moment, but Jim Hendricks has the knack of finding nice old planes hidden under dirt in bootfairs which he restored with lots of photos and helpful detail, eg
scottish-infill-smoother-restoration-t64459.html
and
more-infills-not-landfills-somebody-stop-me-please-o-t46671.html
You'll find more of his work at the WK Fine Tools site, which is also a rich source of approaches and techniques.
You might also find the tool restoration links in this sticky useful:
tool-cleaning-and-restoration-links-t82859.html
User avatar
By ED65
#1194792
That would be a shelf queen for me and as a result I wouldn't know how far I'd go with the cleanup. It's nice to take something all the way back to bare metal sometimes but with really old stuff having it fully looking its age can be really nice.
By richarddownunder
#1194804
Hi. Nice find! If you do get the infills out in a clean-up process, electrolysis of the metal parts works well without scrubbing, sanding etc. Of course, pitting from corrosion is still there but its a gentle way of getting rid of rust and not metal. Best of all it is easy!
Richard
User avatar
By toolsntat
#1194805
Very nice find Rob, time, methinks, to move South :wink: =P~
Cracking working to give it that Cupids Bow on the sides.
Just have a peek under the lever cap. Can never be certain but be nice to see the PRESTON trademark and a size.
As for cleaning up, I would wipe it over with your regular oily crappie rag and then a quick tart up on the bottom.
Give it a lick and see what it works like. You might not like it :wink:
Andy
By rob1713
#1194865
Thanks for all of your input chaps. I gave the plane a quick try after giving the iron a quick sharpen, it worked ok, but as most of my school reports stated, it 'could do much better'
After wieghing up your advice and considering that I wanted to flatten the sole and clean up the sides a bit, I decided to remove the infills. Hopefully this means I can stabilise the crack in the front bun as well.
3 of the 5 screws came out easily but 2 of them needed to be carefully drilled using my old hand drill press. You may notice that there are 2 screw fixings on its port side rear infill and only 1 on the starboard. Upon removal of the infills I found out why this is. Someone in the past has removed the infill and like me had to resort to drilling the screw out, however unlike me they decided to screw in a very short screw and drill another fixing in the casting for a full length screw,rather than carefully drilling/digging out the screw shank.
However things went ok and I learnt a lot about how these planes are made. For instance I didn't realise that the handle profile is very slightly wedge shaped to keep the rear cheeks tight against the casting.
It seems that infills were bedded on a fine layer of some sort of cement type adhesive / filler, I'm not sure if this is the usual method used or whether the last person who removed them decided on a belt and braces approach to refitting them. It guess it does mean I will need to think about adopting a similar approach when I finish work on the casting.
Again I would appreciate any views on whether this is normal or was it a bit of a bodge.
Andy, I checked under the lever cap and unfortunately the was no hidden EP mark just a 2 1/4 stamp. In the unlikely event that I get bored with it I'll drop it off next time I'm passing as long as you get the last restoration job I sold you finished.
Rob
User avatar
By ED65
#1194953
rob1713 wrote:Again I would appreciate any views on whether this is normal or was it a bit of a bodge.
Possibly neither. Maybe not usual but with shrinkage of the wood the previous fettler could have felt it was necessary to pack out the underside to provide a solid footing.
You might be best leaving it but if you want to remove it be a little careful, it could be something innocuous like whiting bound with glue or it could be a oil filler containing lead pigment. Lead white isn't hugely toxic but obviously still best not to breathe any in if any dust is generated, and wash hands thoroughly periodically as you're working on it if not wearing gloves (gloves not being essential).
If it is bound in Scotch glue it'll be soluble in warm water. Might still contain lead as old timers would often throw in some lead to fillers and other workshop concoctions because it was a commonplace traditional ingredient, but working wet like this you'll have no worries about dust. It's safe for it to run down the drains.
After removal you'll probably need to re-bed the wood, in which case an epoxy compound might be your best bet.
It's a very pleasing shape, hope the rest of the overhaul goes swimmingly!
By D_W
#1194989
It's fairly typical to find bedding on an infill, especially an older one.
You want the following (not rocket science)
* a flat sole
* a well bedded iron with a reasonable mouth (filed toward the front as you go to the top of the inside of the casting) and a reasonably tuned cap iron
* good proportions and angles (it looks from afar like you have those)
* infills that are tight and that don't move
The contact with the casting isn't necessary if the cross pieces are tight, just as the cross pieces aren't necessary if the contact is solid and bonded (but that will never stay the case in the long term).
So, the solution is to fit everything as tight as possible and bed the infill into some type of glue, etc.
I use epoxy, but I have gotten to the point that my infills are within about a thousandth of the dovetailed (I'm too incompetent to cast anything) sides and bottom, so it's not necessary. If my planes last long enough, inevitably, the infills may shrink some and someone will have to do the same to them.
By all appearances, you've got a good set of bones there. My suggestion as an amateur maker (and I can't make much, but I can make a good plane) is to do minimal cleaning, get the infills fitted and bedded tightly. Save any bed work to the infills themselves (the bed where the iron contacts) for later unless it absolutely needs to be done, lap the bottom dead flat (File if needed, I can make a video about that if you need it - don't just file away - lapping is safer if the bottom is reasonably close).
By rob1713
#1195193
Thanks for that, I plan to treat the casting using electrolysis then lap the sole flat. The mouth is a bit wide on it, the previous owner had tried to address this by using a card packer beneath the iron to move it forward, I will have to do something similar when I get to putting it back together as the mouth may get wider as I lap the sole to get it flat.
I'm only planning to give the wood a gentle clean and wax as it has a nice patina that I'd like to keep.
User avatar
By ED65
#1195271
Well the cap iron trumps mouth size for effectiveness (and convenience but that's not a winning argument in this context) so I wouldn't worry overmuch if the mouth is wider than some fans of infills insist is ideal, i.e. absolutely tiny, a small fraction of a mil.
From the initial photos the gap in front of the iron looks plenty small enough to offer no problems in normal service.
By D_W
#1195299
rob1713 wrote:Thanks for that, I plan to treat the casting using electrolysis then lap the sole flat. The mouth is a bit wide on it, the previous owner had tried to address this by using a card packer beneath the iron to move it forward, I will have to do something similar when I get to putting it back together as the mouth may get wider as I lap the sole to get it flat.
If the mouth is large enough that it makes it hard to start the plane without leaving marks on the end of a board, it's a problem. If not, I wouldn't worry about it.
User avatar
By ED65
#1195318
Well none of these gives much trouble with that:
Top one is my super smoother, 2mm gap. Bottom one is quite a respectable performer, 3mm gap.
I do have a woodie where this is a definite problem but it has a gaping maw for a mouth!
