Glazing, acceptable tolerances?
Geoff_S
12 Sep 2017
London
I am "re-purposing" a walnut four panel door. The idea is to turn it into a table top with four glass panels.
Now, I measured and ordered 4 panels of 10mm toughened glass and they have all arrived 1-1.5mm longer than I specified.
Should I consider this acceptable and buy a 1mm rebate cutter?
Why not just contact the supplier and tell them the glass isn't the size you ordered?
as I understand up to +/- 2mm is glass industry norm for being accepted for construction
But it is, to a 2mm tolerance. Hence the question.
See also the recent thread discussing errors and tolerances w.r.t. squares.
BugBear
If they quoted +/- 2mm and they came in at 1.5mm then they met the specification you agreed in the contract established when you ordered from them.
you would normally order glazing with a 3mm smaller than the frame you are trying to place it in.
Well I never knew that.
Gave you a thanks/thumbs up for that. We learn something new everyday.
Interestingly, there are no terms & conditions that I can find on their website and by the looks of what they do and what they charge, it's no Mickey Mouse organisation.
But, one of the reasons that I ask is that in the mists of time I have heard this +/- 2mm tolerance. So if I have an inset length of 1000mm, what should I order? That should be 997mm, but with a potential to actually receive 995mm.
That's a potential of 5mm difference! One man's tolerance is another man's gap!
I have done that and am awaiting a reply.
But it's quite cathartic coming here \:D/
They've just got back. Yep, industry standard +/- 2mm tolerance blah, blah, blah.
It's a pity I cannot pay their invoice with a +/- £2.00 tolerance.
Personally I allow 3/4mm on single and 5/6mm on double glazing. The variable depends on how bang-on-square my door/window is. If the wood moves with tight glass you know what’ll happen!
I always give the glaziers rebate sizes then if the glass doesn't fit it is their fault.As long as you have measured correctly.
The glazers I used a few years ago would regularly make them to the rebate size, I now give ‘make’ sizes for everything!
