I made a small one of these a few years ago. It's not a bad performer, but rather pint-sized (75mm sole length, 25mm blade width), and a little basic-looking:
Since that time I've moved on to making screw adjusters, which I included on my second chariot plane. This one is a bit of a departure from most of the original CPs in having a longer toe, not a 'bull nose'.
With still a few decent-sized scraps available, I decided to make another bull-nosed version to match #2. More or less - it has the same sole-length & is based around a 35mm blade (used on the Stanley 61 1/2 & clones).
I think dovetailing plane bodies has been well-covered on this forum, but here are a couple of details that might be of interest to would-be plane makers.
I wanted to add a rear cross-piece about 6mm thick to drill & tap for a stud for the adjuster. I could have drilled right hrough & used a couple of long rivets to retain it, but there is very little room & I was afraid I'd end up with a rivet right where I wished to drill for he stud. So I used 'short' rivets in a way I'd road-tested some time ago. The method involves drilling into the cross-piece about 7-8mm & tapping a 3mm thread into them:
Cut a matching thread on a bit of 3mm brass rod, screw it in firmly & cut it off about 2mm above the surface:
The projecting bit can then be peened down into a countersink & filed flush to the surface. Destructive testing indicates the rivet is as strong as through-riveting, the 'head' fails before the thread strips.
Apart from keeping the fixings out of the way on the rear piece, setting up the nose-piece in a similar way allowed me to finesse the mouth & check it before attaching the nose permanently:
Once I was satisfied I had the mouth right, the 'rivets' were installed & peened:
With everything sorted to my satisfaction, the wedge/lever cap was shaped & the parts all cleaned up & polished ready for assembly:
Turned out a goodie - the adjuster works smoothly and is reasonably fine (the stud is M5). There's a bit of backlash because the wheel that engages the slot in the back of the blade has to be loose enough to allow lateral adjustement. Backlash in depth adjusters has never bothered me, but I know it irritates some.
This plane is getting close to my idea of perfection, but it does have one blemish, just to keep me humble. I didn't support the front of the mouth when peening the sides & I managed to distort the pins a bit more than I should have (live & learn!). That meant lots of filing both internally & externally (before the nose was added) to clean things up, but on one side I'd pushed the pin too far out of whack & there's a slight ding that wouldn't file out.
Functionally, it's well up to standard, so I guess I'll keep it:
Cheers,
IWW
Cheers,
IWW
