Yippee its here
So not what you expected then :lol: :lol: :lol:
I keep trying to move the various bits on the lathe around and keep reaching for the levers in all the wrong places, I will soon get in the routine of where the levers are on this one.
petercharlesfagg":1to6k24x said:
Just one quick question:-
Have you run-in the front bearing?
It usually takes an hour or two?
It seems that you have been very quick into using it?
Regards, Peter.
I ran it for about 1 1/4hrs before using it while I was tiding the shed, and the obligatory cuppa after installing it. I had to use some 30W oil(as recommended in their instructions) but will be getting some of records own oil.
Deejay":2z7ck0tx said:
I don't think the RP oil is anything special.
:shock: :shock: No you're wrong, it must be special - look at the price they charge for it :shock: :shock:
I'm with Deejay on this one - any good quality 30W oil will be fine :)
Regards Mick
I bought mine secondhand and can't remember what oil came with it. As I run an old Land Rover I've been using gear oil in the lathe for years now, GL4 spec which doesn't harm phosphor bronze bushes in gearboxes.
