Hi there - yes,for £200,the Perform range would certainly get my vote.
Started off with the Clarke 20" lathe from Machine Mart:-
which was about £70 - had fun with it for about a year or so,then (due to an unexpected bonus at work) upgraded to the Perform CCBL:-
which was about £200.
No belt/pulleys to alter to change speed - so I change speeds more often
No spanner needed to move tailstock/toolrests - so I move them more often
Bear in mind other costs,though:-
Chisels - my first HSS chisels were the five-piece set behind the headstock - £50
Chuck - although I made lots of things on the small lathe between centres,or using a faceplate or screwchuck,having a chuck now makes workholding easier - Clubman K10 currently on offer for just under £100
So,for what it's worth,that would be my recommendation for a lathe in your budget - has the capacity and capability to be added onto as and when you can afford it (assuming you get addicted :lol: )
Good luck,and let us know what you decide to go for.
Andrew
P.S. - still an enthusiastic amateur,and not an expert :wink:
