Shoulder Bolt
SteveF
16 Sep 2013
Maidstone
would someone be able to turn me a shoulder bolt please
I have looked on-line but cannot find anything suitable
this is a quill lock for my drill press
I just need a longer one...don't ask lol
it is metric and has a 10mm thread I believe, but will check
I can get all correct dimensions if someone is interested to do a "one off"
I would be happy to post the original one to be copied
Steve
I'm surprised none of the (current) 64 viewers have responded.
By all means post a drawing (sketch) or PM me the details and I'll certainly look at it.
Post the exact dimensions here. Somebody on the planet must supply one. :-D
Hi J-G
I guess not everyone has time to do this
but if they do
I need the 14mm part to be 30mm longer it would not need to be "cross" tapped for the M6 and just through tapped
Steve
That's a simple project which I suspect would take me less than an hour - once I have the material. I've just checked and I don't have any 14mm EN1a on the shelf but I could source it within a day.
I presume that it doesn't need to be Stainless.
Confirm that my drawing corresponds with what you need and PM me your postal details if you want me to proceed.
many thanks to J-G for sorting this for me
what a great forum for like minded people, willing to pay it forward
Steve
Because this may be of interest to other readers I'm posting here rather than sending a PM.
The alignment of the handle which fits the M6 cross drilled hole may be important but since I didn't have the Drill Press I couldn't fit the bolt in position to determine the appropriate orientation. Therefore, Steve, if it's position is important, you may need to do one of two 'adjustments' to change the position.
If the M8 thread 'bottoms out' then you could grind some off the end, but if the 'shoulder' (the 8mm to 14mm change) bottoms out then adding a washer would do the job.
A change of 3½ thou would change the orientation by 10°.
Cor, sorry I missed all that! My laptop has been away to the "Dr" for a few days (don't you curse 'em when they're here and miss 'em when they're gone? A bit like wives I guess!). Anyway J-G's done a nice job by the looks n sounds of things, AND his postage must be cheaper than mine from here (though forgive my ignorance, I'm not really sure where Atherstone is).
=D>
AES
About 11 miles north of Coventry - close to the Warwickshire/Staffordshire border.
