Narrow countersinks?
Eric The Viking
19 Jan 2010
Bristle, CUBA (the County that Used to Be Avon)
I'm really frustrated.
I was trying to use a very short length of T-track, 3/4" size, to fix an issue with my bandsaw table. It's going to be surface-mounted on one edge of the table.
So I drilled a mounting hole and carefully tapped it to M4, and put a countersunk machine screw in to hold the T-track temporarily in position. The second hole was done by drilling through both the T-track and the cast iron together, so that the T-track stayed aligned correctly (even if the location of the hole wasn't spot on). This also worked a treat.
I was reaching for the M4 tap again when I realised what a twit I've just been: the first hole I used was a pre-drilled and countersunk hole in the T-track. It came with them already drilled at regular intervals.
The second hole, on the other hand, has no countersink, and it seems I can't make one as I don't have a countersink that is narrow enough to reach down through the open slot in the T-track (about 8.2mm across) to make it!
Any machine screw not countersunk properly will get in the way of the square nut that needs to slide in it. So no countersink on the hole = can't fit the T-track to the saw :-(
So I rummaged around and found my smallest snail-shell. That will just about slide along the track and I can get the point into the drilled hole, but I can't rotate it! I even wondered about reducing its diameter, but I think it would end up in two pieces. That idea isn't going to fly.
D'oh, as Homer would say. ](*,)
Can someone please point me at a source of supply for small (i.e. narrow) countersinks?
Failing that I can always freehand grind the point of a twist drill, but the result probably won't be pretty, and it's a lot less controllable too. Actually I can use the depth stop on the drill press for that bit, so it may be possible...
TIA
E. (feeling idiotic).
Could you not just put your normal sized countersink in the drill and hold it against a grinder to 'narrow' it?
...or...
Can't you slide the countersink bit down the track before mounting it in the drill?
Tried the second - slides along but can't rotate.
Was just looking for another narrow-ish countersink I think I have (might have a lead now: Interpol has been very helpful...). It will almost certainly be too wide, but it's the old multi-fluted type so can be ground.
With a snail-shell, although the finish is lovely, you can't make it any smaller than the hole drilled through it!
Edited earlier post: track is approx 3/4" and slot is about 8.3mm wide (narrow part).
Just drill out the upper part of the T track to the width of the countersink bit. That small an area isnt going to impinge on any safety aspect of the track.
It's not being used that way, sadly it's for clamping.
Found the other countersink: It's a gnat's under 10mm.
So I've got choices: either lose 1mm off the radius or regrind a 7.5mm drill bit (have a few). I'll have to get by without a clearance angle but that may be a good thing.
What about a self countersinking screw
It's not massively quick, but freewheeling it the hole with a screwdriver created a countersink
It did make the aluminium quite warm though :lol:
Coley
Sent from my SM-G900F using Tapatalk
Grind off the bottom of the clamping bolts till they slide over the screw head.
Spun the narrowest conventional countersink I have against the grinder - worked reasonably well except that the battery in my drill died and it started to oscillate a bit as it slowed down.
The result is something that looks a bit like the rotor of a Wankel engine, but it did work.
Thanks all.
E.
PS: I think Coley's Idea would have worked too.
Eric, have you tried ordinary centre drills like wot they use on lathes? I freqently do and they cut most metals "like buttah" and leave a nice finish. Skanked in most drills, there should still be enough 'throw' to clear your metal edges.
Sam
The angle on a centre drill is 60*, a countersink is 90*. In this application it will probably be fine, but it will mean removing more meat than a 90* countersink would.
I'm aiming to tidy-up my mutilated countersink (it works but scuffs _very_ slightly on the edges of the slot - just needs to be round rather than a 'tricorn hat' shape).
And if I coke that up, Plan (b) is to do what Rorschach and Dave suggest and re-grind an 8mm drill to 90deg, and use that (have loads of suitable blunt-ish 8mm drills).
Cheers, E.
If the job can wait a while, I have a few old style flat countersinks for use in a brace. I am pretty sure one or two would be small enough.
SammyQ":2tducngk said:
Think I'll invest in a couple od spot drills though.
Sam
Likewise, I never knew they were available in 90*
