Chuck keys
DTR
11 Mar 2011
Essex
Greetings all,
How does one work out what size chuck key to buy?
I recently bought a model-maker's bench drill from the wife of an enthusiastic engineer who had sadly passed on. The drill is most likely home made from raw castings. (I also came home with a Cowells hand shaper, but that's another story!). The drill chuck has a capacity of around 3/8" (I think), and the hole for the spigot part of the key is 5/32". Despite searching high and low in his workshop, no key was to be found.
Can anyone please point me towards what size key I need? Thanks!
Last time I needed one I just took the drill to the toolshop and asked for a key to fit. That is what I would do, but I understand that there might be no proper tool shops in Essex. [I think I recall seeing mention of a good one in Leigh on Sea, where my old aunt used to live, but I digress...]
More helpfully, this page from Chronos will at least give you an idea of the sizes that are available so you could buy one and try it.
http://www.chronos.ltd.uk/cgi-bin/ss000001.pl?page=search&PR=-1&TB=A&SS=chuck+key&ACTION=Go
In case it is any use I have just gone and measured the key on my old B&D Electric Drill which also has a 3/8" chuck which was probably a common one in the 70s. The pin is 15/64" and the pitch of the teeth, measured in the middle of the taper to give an average size, is about 3/32", so probably not what you need.
You could measure the pin by using a set of drills as gauges and checking which drill fits, presuming that you have a set of imperial sized bits. And assuming it's an imperial sized chuck...
i bought a key from eBay for a couple of quid that had 4 sizes on it. Predictably, it was made of cheese and broke the first time I used it, but something similar would tell you the size to buy a decent one of.
Chronos was the first place I looked but I still managed to miss that page..... either one of the 4mm chucks might do it
I've already measured the pin, it's 5/32" ;) (or 4mm in new money)
I thought about that but even the smallest looked too big. Are the sizes labelled on each key?
I think that they were. if they weren't, i knew the 4 sizes that I had bought from the listing.
So I ordered the two sizes of 4mm chuck.... and they both fit equally well :-k
The larger key has a slightly different tooth profile, so it still meshes ok. Learn something new every day.
I mentioned this briefly in another thread. I originally thought that the drill was home-made from castings, but something wasn't quite right. There were parts that were obvious diversions from the original design, but I just assumed that the original owner had used whatever parts he had to hand. Later on I realised that it was actually a conversion of a hand cranked drill.
I still need to install a table and an NVR switch, but I'm looking forward to using it.
Thanks for the help chaps :)
