You need both roll pins fitted, do not try to change the holes as they would have been drilled with the table and fence set properly. They create a proper reference, something else is loose. With the roll pins inserted and the casting with the hand wheel bolted up (it won’t move with the roll pins inserted) nothing else holding the table to the base maters for fence alignment.
It sounds like someone has been ‘playing’ with the saw. I’d next check the L shaped brackets are tight and adjusted properly.
Im in a similar bind to @guineafowl21 fetling to try and get the blade aligned to the mitre slots. I get it aligned with just one pin in (RH) but when the other pin goes in, it takes it out again!
Can you elaborate what you meant by the hand wheel @deema pls? and the L brackets? I could see anything in the standard diagrams/manual…
cheers
