Advice Please- problems with Rust-oleum Chalk Paint
PlacidCasual
3 Jun 2017
South Wales
Hi Guys
I’ve been building kitchen cabinets in advance of doing the kitchen and the wife has settled on Rust-oleum Chalk Paint. I’ve built the first 2 painted then then sealed with 3 coats of Polyvine Hard Furniture Varnish (satin). And whilst they are not perfect I was pretty happy with them and imagined I could be neater second time round.
So the first 2 are ply construction, sanded to 240grit. Under coated with a Johnson’s aluminium based grey hardwood primer/undercoat. Also sanded to 240grit. Then 2 coats of chalk paint applied by sponge roller. For the flat surface I eventually wet sanded 320grit and applied a final coat with a sponge brush. So there are a few marks near the corners where I couldn’t correct some of the roller streaks by sanding. But these are going to be the least visible cabinets so rather than chase my tail I accepted the finish and varnished. 2 coats with a brush and third coat on flat with a sponge brush.
I know that all sounds faffy but I was using these first two to learn what worked best, or so I thought.
Ok so on to the next 2 one of which is an open fronted cabinet so very visible.
Same surface prep and undercoat. But I decided to apply one sponge rollered coat then sand lightly the 2 sponge brush coats wet sanding between coats. But these have been a disaster. I was getting really bad brush marks from a fresh can of well stirred paint. I tried watering it down which has reduced the brush marks but I’m still getting them and it feels like I’m wet sanding off everything I put on. Now I’m also getting bubbles forming as I brush. It’s pretty warm maybe 28 or 30 in workshop for latest problem but hasn’t always been that hot and still had terrible brush marks.
I’m about to go to a velour short hair roller but could really do with some advice.
Edit, the sponge brushes are Chestnut Jenny brushes from Axminster
I haven’t contacted Rust-oleum yet. I may do if problems persist.
Tried again today, temps a lot lower and paint behaved a bit better, I went for thinner coats, still some brush strokes but far less problematic.
